WANTED: 2005 BAJA 2.5 NA MANUAL TRANSMISSION
seriousfestival
Post by seriousfestival »
Hey guys, looking for a 5 speed manual in working order. Ours shifts and operates great, however it has a horrible noise from the front differential. To our knowledge, we can't find anyone that will rebuild it, so we're looking to get a good used replacement. So far can't find any used 5 speeds with the push type clutch and 4.11 gears. If anyone has one or a possible lead on one, please let me know!
theluckyone17
Re: WANTED: 2005 BAJA 2.5 NA MANUAL TRANSMISSION
Post by theluckyone17 »
It's been a long while since I replaced the transmission in my Baja, so I'm fuzzy on the details. I pulled a transmission out of an Outback... dropped in without a problem, and the final drive ratio matched that of the rear (4.11?). Fifth gear was a bit taller, so it dropped the RPMs on the highway by a few hundred. Can't remember which year it was, though.
Believe I used this chart as a reference: http://www.northursalia.com/techdocs/tr ... ychart.pdf
Onyx: 2006 Baja Sport
