Question on loose steering
Bulldog-Baja
Post by Bulldog-Baja »
Question on slightly loose steering on the highway:
I have an '06 Baja Turbo AT, that I've lifted 2" and installed 16" rims and 235 60R16 tires, ....and installed new front control arm bushings.
The car has also had an alignment. However, on highway speed, i.e., 70+ ...the steering is a little loose. I was thinking of replacing the steering rack bushings with a good poly bushing?
Anyone out there have a similar experience and am I on the right track here regarding this?
Thanks in advance!
tonys123
Re: Question on loose steering
Post by tonys123 »
Yeah you might want to fix it before it ends up like mine ImageImage
https://vm.tiktok.com/ZMdnmG4Ed/
Sent from my SM-N960U1 using Tapatalk
Bulldog-Baja
Well that makes for some exciting driving!
Suddenly, ...my steering doesn't seem that loose :)
Cheers
20Baja06
Post by 20Baja06 »
tonys123 wrote: Fri Jul 23, 2021 9:39 am Yeah you might want to fix it before it ends up like mine ImageImage
What in the wild wild world of sports was the culprit there?? :shock:
tonys123
Post by tonys123 »
I belive the gears in the rack were spilling idk it started off slipping and holding off center . You would have to jerk it back to center, then slowly got worse slipping all the time lol ..
