Dear Baja Owners,
I'm new to the club, but really like the car (truck?) so far. My Baja, a 2005 SportShift Turbo, has been sitting for a while. The engine seems to "pulsate" throb or surge with perfect throttle. That is to say under steady throttle, the car will rev up to 1200 rpm then back down to 900, then up again, to 1200 then back down to 900. It slightly affects the speed of the car, which is still more or less drivable.
The Subie dealership thought it was the throttle body, and cleaned it -- but it didn't solve the problem.
Has Anyone had this problem or know the solution?
Pulsing / surging Baja engine
Re: Pulsing / surging Baja engine
Since this is your first post, we don't know much about you. Do you have much skill or many tools for working on the car? How about electronics (where the problem likely lies)?
Other than this issue, does it make power? fuel economy within normal?
Any mods or is it stock?
Maintenance up to date? All the fluids changed?
Any check engine light?
Any recent work done?
Does it do this when you're stationary or driving? What speed? One gear or all gears?
When the RPMs drop, is it smooth like the throttle is closing or ragged like a misfire?
If you can read the ECM live data, graph the accelerator pedal position vs Throttle position.
This is gonna sound silly, and the issue prolly wasn't a factor in what eventually happened; but
The '99 outback I had in high school had a similar issue. It idled 800ish high, then would chill out after about 30 seconds, then spike back up. I never found out what caused it.
That car eventually died to a cracked engine block from a failed radiator (high school me didn't notice some obvious signs).
I have no evidence that there was any connection between the issue and the failure. Logically, I suspect they weren't related at all.
But failing any good ideas, it's something to check if you can do so affordably.
Edit: The post above that came through while I was typing has much better ideas.
After binging car videos on YouTube for 3 months I have very good understanding, but 0 time with a wrench, and 0 tools...
I think they're good. Everything works in the car except the windshield wiper pump, which I need remove and test.
Yes, the car is very zippy, and after taking delivery, I know I don't want to put crazy horsepower into it because it's already almost enough to "get me into trouble" since it will be my daily driver.
It drinks fuel from what I can tell.
Stock.
Yes, I had the official Subaru dealer inspect and do any outstanding maintenance.
They replaced the rusted brakes and some hoses.
They should be, but I shall put this on my to-do list.
Yes, the dealer charged me about 20 bucks to tell me the error code is the front O2 sensor -- so I've ordered another.
And another 50 to clean the throttle -- which was supposedly the cause -- but it didn't work......
When driving around town.
> What speed?
ca. 20-50.
Noticeable in 2nd and 3rd.
It's smooth like someone is opening and shutting the throttle.
I can't, I'd like to get a Cobb access port to read the engine data, but apparently the Baja isn't supported.
I know there are other readers, but it seems a bit hit and miss on the coverage of the data.
Stock.
> What speed?
ca. 20-50.
a generic OBD2 to bluetooth reader and the torque app on your phone would be enough to read live data.
I've had great luck with the $10 bluetooth OBD2 readers from Amazon and spending the $5 for Torque Pro. Highly recommended for tracking down this kind of problem.
Gray 05 Turbo AT
Silver 04 Turbo AT
Black 04 Turbo AT
Silver 04 Turbo AT
Black 04 Turbo AT
