FlyByNite wrote: Sun Apr 21, 2019 12:25 am
Indiana uses salt on their roads, that might be what messed up the paint. I would get it on a lift and look over the underside for rust and rotted bushings.
salt doesn't bother paint and certainly doesn't do THAT to paint. something poured on the mirror to do that. Salt causes rust which rots the steel and AL under the paint and plastic from the bottom up.
While it has IN plates currently, where matters: northern is a totally different climate than southern. Plus the bob boast VW sticker googles up to be in florida near the coast (sea salt rather than snow salt) and the paint damage could be sun.
-It'll probably need struts. Subaru uses some magic in their struts that they last a long time but they're due even on a subie at that point.
-the wiring coming out of the dash is a flashing yellow warning light... where does it go? what does it do? what other wiring was hacked up to do it?
-hoses, coolant, transmission oil, diff oil (both), power steering fluid... plan on all of it being original. Same problem with old toyotas "no major repairs" "hasn't needed anything" also means not a darn thing has been done but change the tires and brake pads when they fail. The manual has a whole slew of periodic maintenance to be done. That the seller did work themself also means it probably hasn't been on a lift to thoroughly shake down the suspension or check things over underneath in a while.
-No engine bay pics, no way to know what's going on in there.
regarding the banjo bolt filters... extended oil changes cause the filter to fill up and oil can bypass it. When that happens the gunk gets stuck in the banjo bolt filters rather than going through the AVCS and turbo. The banjo bolt filters plugging are a
symptom not a cause. If everything else were right, there would be nothing in the oil to be caught by them.
