Towing with the Baja
Ok, how many of you have tried towing with your Baja? I have towed my ATV twice with mine. 03 n/a, with auto trans, with a cooler that I added. Trailer weighs about 400 pounds, and the ATV about 750 pounds. So its a pretty good load. I am impressed with how it handled it. Not like a big truck thats for sure. I tried it on the freeway this time. It spent most of its time in 3rd gear, at 4200 rpm's to keep up with traffic at 70 mph. Also had the a/c on, so that sapped alot of power. Mileage also dropped from the 26 I get back and forth to work, to 18.6 towing. I didn't think that was too bad for the load it was pulling. Anyone else tried towing a bigger load like this? What was your experiences with the beast?? Mike
- cyphergirl
I want to tow one of these puppies:
http://www.tab-rv.com/
...but I'm just not sure about it (1346 lbs unloaded).
Me? I have a Sport. I have read in a few forums where ppl are towing a T&B with an Outback. But I'm at 5000+ feet, and just about anywhere I would take the trailer would take me over passes at 10,000+ feet. I'm not real sure the Baja could do it.mbaksic wrote:Thats prolly a little bit more than when I tow, so you will have quite a load. Do you have a turbo or n/a Baja?? Mike
- BajaBear
Hey! that T@B is based on the old teardrop trailers! I'm look'N into getting a teardrop myself. They tend to be a bit lighter to tow. This is a cool link:jaxed wrote:I want to tow one of these puppies:
http://members.1stconnect.com/anozira/S ... 20Trailers
2005 Turbo
Atlantic Pearl Blue
Atlantic Pearl Blue
Just got back from vacation. Towed the atv from SE Wisconsin to the yoo pee of Michigan. It sucked a bunch of gas, I didn't even check the mileage. It handled the trailer and atv pretty good. Lots of downshifting into 3rd gear, so the tranny got a workout. I am glad I put a tranny cooler on it last year. Most of the downshifting was with the cruise on to keep up with traffic at 70 mph. When it was flat, it would stay in overdrive, but as soon as you came to a little upgrade, the convertor clutch would disengage, then the downshift into 3rd gear. At 70 mph, thats about 4200 rpms. It would hold 3rd gear until you went downgrade, or the road flattened out a bit. But I could keep up with traffic ok, just worked the hell out of it. When I got off the interstate and onto 2 lane roads, it kept up much better. Not so many downshifts, unless of course you came to a hill. So it will tow, but if you have a auto trans, GET A COOLER!!!! Mike
- Mr. Jalapeño
It was kinda a pain to do, I did mine at the dealership I work at so I could use my hoist. I bought the smallest cooler that I could at Car Quest. It would fit on the right side of the condensor. I had to pull the bar out that holds the horns to have enough clearance. Then removed the right headlamp to run the hoses through. I had to enlarge a hole in the radiator support behind the headlight to get enough room to run the hoses, took the existing hole and chopped it strait down with my air chisel so I had more room. I also cut off the lower headlamp mount so I had more room for the hoses without kinking them. I heated the back of the right headlamp also and kinked it in so I would have more room. This did not change the headlamp pattern at all, since the reflector is inside of the headlamp. I removed one of the factory hoses, which should be the return line to the trans, and installed it on the cooler, since one of the hoses had to bend really sharp to make it to the cooler. This factory hose had a 90 degree bend, so it was perfect. I used the hose that came with the cooler kit in its place. Then tie strapped the hoses together so nothin would rub or chafe through. Took me about 2 1/2 hours. Maybe someone else has an easier way to do it. This worked for me. Sorry, no pics, as I did this at work last July before we had this forum. As far as I know, Subaru does not offer an auxillary cooler, so you have to make due with a generic aftermarket one. Mike
