Towing with the Baja
Ya Cliff, it was an ok project. If nothin else, your vocabulary gets a workout!! But if you want to tow, I see no other alternative to makin a cooler work. Otherwise you will fry the trans, or at least shorten the hell out of its life. I usually put one on any car I have owned that could be used for towing. It also helps to reduce the trans temps while driving normal also, so it should help out all around. Mike
