Sorry to see you go!
Not that this'll help any, but mine's missing little things left and right: there's about 15 interior plastic clips gone that are supposed to hold in the interior panels in place, the latches to pull the rear seat down have both broke and have been replaced with and abomination of literally copper pipe and plastic cabinet handles...
the previous owner
HAD a soft bed cover but the stealership I purchased it from gorilla-glued some god-awful plastic plugs over the drill holes to cover them up and now they're so oxidized they're basically pale grey and one is actually missing leaving a gaping threaded hole in the plastic liner, the liner on the passenger side looks like someone attempted to clean it with lacquer thinner or something as there's a giant 5in wide spot where the plastic has literally melted away partially, the PO was a smoker and the front seat has burn holes in the upholstery which is also torn to hell on the left side of the seat, the passenger side rear window motor squeals like a banshee, the rear window defroster has 3 bad lines that are coincidentally right in the middle of the window and right in the line of sight, the front bumper is pushed in 1/2in on the driver's side and is missing ALL of its retaining clips under the hood, the VIN plate is seemingly missing under the hood as well, the passenger front seat headrest doesn't lock on any of the extended cutouts, the silver plastic dash panels have black paint randomly splattered on them... somehow, the rear-view-mirror has a damn oily fingerprint mark off to the left side that is under the protective covering, the driver's side roof rail is cracked clean through at the back and only a single bolt is holding that part in place, the exhaust header has leaks everywhere and what's left of the the gaskets rattle like hell when driving 50mph+, every mounting bolt to the chassy is rusted to hell and back to the point where they will snap off if I try to loosen them...
and this is all what's still wrong now, after I've had both front axles, all 4 brake pads, rotors and bearings, cat-back exhaust, both headlight housings, and finally the timing belt (this is the only one that's regular maintenance though) replaced... and now one of the front and rear brakes are making funny noises...
but as long as this car/truck/thing still has a running engine, I'm driving it and I'm loving every second with it.
I'll end this post with a quote from Winston Churchill...
