LGT wagon suspension in Baja. It's done, and it works.
SVO1
Post by SVO1 »
Going in Friday for an alignment, everything thus far is close.
Running the stock 225/60/16's, and they are really close to the spring perch, but are not hitting. (with a different tire brand who knows).
KYBgr2's and stock springs for an 04 LGT wagon. Stock Baja upper mounts.
I did remove the rear bump stop.
Before:
after:
Took a short drive and hit some speed bumps/hard driveway approach angles and no rubbing. seems to ride decent!
McBrat
Re: LGT wagon suspension in Baja. It's done, and it works.
Post by McBrat »
:) I thought I saw that pic before :)
'03 Baja Sport, Baja Yellow. Snuglid.
'82 Brat, custom coil/link suspension, Toyota solid axles, Samurai t-case, built ea81, 5 spd d/r, 36" swampers.
