My goal is to see about 1.5 to 2 inches raised from its current height without suffering any ride quality/handling. Can I just swap in four new taller springs ??? If so, please respond which one and whether or not you've done it or know of one who has. Ride quality is my most concern. Please let me know. Many thanks.....
2003 Baja ride height raised ???
Re: 2003 Baja ride height raised ???
This site will show you Scorpion lift Springs for a 2003 subaru baja.
http://www.renickmotorsports.com/oscomm ... 88cd3b083e
I call them and they indicated that the front springs are SOLD OUT. So no go. I read here that I can just buy the 05 springs and put them on my 03 to raise it by 1.5 extra inch. If that is the case, it is very likely what I'll be doing since fronts are $38 each and rear are $39 each. Any other suggestions are welcome. Thanks.
K.
K.
YBajaSteve
kmvbaja wrote: If that is the case, it is very likely what I'll be doing since fronts are $38 each and rear are $39 each. Any other suggestions are welcome. Thanks.
Take before and after pics, cuz I'll be following right behind you, if its worth it! Also Where did you find them for that price? Thanks
