H6 EZ30D Engine Swap Into the 2003-2006 Subaru Baja
subarukenny_d
Re: H6 EZ30D Engine Swap Into the 2003-2006 Subaru Baja
Post by subarukenny_d »
Reserving this reply area for project updates.
2005 Black/Grey H6 Baja Sport A/T
Follow @Subarukenny_d on instagram for Baja updates
subarukenny_d
blitzinq
Post by blitzinq »
Hi subarukenny_d, thank for you for all this documentation!
I am in the process of doing the same swap in my Baja. I am most of the way through it but have 1 or 2 gotchas I am working on, was hoping maybe I could reach out and pick your brain some! I see you are also from PA, as am I!
I am new to this site, maybe I can shoot you a pm?
subarukenny_d
blitzinq wrote: Thu Jul 04, 2024 9:35 pm Hi subarukenny_d, thank for you for all this documentation!
Go ahead, a lot of information can be also found on the H6 Swapped Subaru's page on facebook as well. Or some of the baja pages I and a buddy of mine who also did the swap/compiled information with me has good info there.
DisrespectedBaja
Post by DisrespectedBaja »
Not as planned as I wanted it to be, but my engine went on Baja, so this time..... 😁
@kenny......are you in Eastern PA? I think I met your dad at a funeral last year....
I may have to swing by and see your build. I love the black on black. Couldn't be choosy though. Nice Bajas are expensive these days. Of my speedo was hooked up for the last 2yrs I'd be rounding 450k mi 😊
Anyway, found donor, now need the time and space to tow it and take apart. Also on a time crunch since the dead one is sitting at work.
DisrespectedBaja
For anyone else following along; something to take note of:
I'm at the point where I get no fuel unless I jump power and ground to the pump. I have no comm with the ECM and my dash stays lit like a Christmas tree even with the key off and out!
What I think is the culprit is the fact that I wrongfully thought I didn't need to swap the FRONT HARNESS and fuse block. Looks like I'll have to pull that out and swap it. I will let you guys know. The more info I can help add to this write-up the better. All credit to the OP no matter what I list here 🤝
