light bar/plate mount
Texas S
Re: light bar/plate mount
[quote author=bajabob link=board=gen;num=1108241184;start=0#14 date=03/04/05 at 10:08:10] I had the impression that the parking brake had to be on for the sport lights to work <br>Bob[/quote]<br><br>Oooh yeaahh forgot about that!<br>
Baja_Turbo
I'm going to pull my console to see if i can jump the E-brake switch so you don't have to mess with the brake to work the lights.I think it should work but it might affect the brake light,will soon find out.
- bajabob
OK finally got the light wing mounted premanatly today as well as bolting the lights to it. Hopefully tomorrow I can finish the wireing<br><br>Carr lightwing with Hella FF200 lights<br><br>
<br><br>
<br><br>The lights are slightly oval in shape and have a driving light pattern<br><br>Bob
<br><br>
Looks great Bob, it almost makes me want to get that old bar out, clean it up and mount some lights to it!!!!! Mike
cliffhanger
- bajabob
I wound up using some threaded rod and coupling nuts to tie back into the steel bumper beam. You have to drill 3 new 1/2 inch holes in the bumper to do this but the plate will cover them even if you remove the bar later.cliffhanger wrote:how did you end up mounting light wing? looks real good anyway...
Bob
cliffhanger
hookupny
I just mounted mine directly to the front license plate frame.. works just fine and I found Baja badged covers... pics here at my website:
http://edsbaja.4t.com/index.html
