made it so i can detach easy if i need to take off the cargo basket
Ok first step - i figured out how i was going to run the wires into the car. i was able to wiggle and pry the top plastic off the truck, even tho the hayes manual and the subaru instructions say you have to take the whole bed apart.... i didnt..... but i did loosen the side plastic by taking apart all the clips i could remove on the right side around the sports bar.
- taking it apart
toook out the 4 screws
this is where i figured id run my wires thru
This is a pic of the completed top, i just ran the wire along the roof racks sides, and used black tape to secure them, this is what i assumed the subaru instructions for the sports lights is telling you to do, since i got some ideas from those, i dont know how long this will stay, i may have to figure something else out.
so i needed to take the interior pieces apart to be able to get at the wires, so i took the headliner down, just in the back, and the plastic interior moulding at the top
had to take the handle off too.
this is the wires running into the cab...
my idea is to run the wire into the cab above the headliner and down the pillar between the front and back door.
