Parting out 2003 Baja. Located S.E. ohio.
ratfink
Post by ratfink »
I bought this 03 without an engine. Manual trans still there and available. Pretty much a complete Baja otherwise except for the parts I needed. Let me know what you need. Thanks, Tom.
greymud
Re: Parting out 2003 Baja. Located S.E. ohio.
Post by greymud »
spare tire hoist?
05 NA 5MT
ratfink
Post by ratfink »
Mornin greymud, I went out to the garage this morning to make sure hoist worked and to remove it from the car. Works good. Rusty but very useable. Brackets are solid enough to be used as-is. Also pulled bracket above tire. Condition not as good but useable. $50. Let me know if this will help you. Thanks, Tom
greymud
Post by greymud »
I don't need the cage, just the hoist. The cage prevents holding a full sized tire.
Does that save any $? also, including shipping? also also, venmo OK?
05 NA 5MT
greymud
Post by greymud »
I'm an old school guy, myself. I would say you should probably remove that personally identifying info from a public post. I'm a bit on the paranoid side of that, though. I'll send you a private message and get you a check.
05 NA 5MT
ratfink
Post by ratfink »
I don't know how to delete my info. I sent a private message to the moderator asking for help. Hopefully they can help me. Tuesday I will ship the part out to you. I will check around for the best rate and let you know Tuesday night. Don't send the check till you get the part and make sure you are happy with it. Thanks, ratfink. (see, I'm learning.)
20Baja06
Post by 20Baja06 »
Does it have a bed extender? May be looking for the mounting brackets + hardware. I imagine others might be interested as well.
ratfink
Post by ratfink »
Sorry Bed extender and brackets already sold. Thanks, ratfink
20Baja06
Post by 20Baja06 »
Not surprised. :lol:
Appreciate the follow up!
ratfink
Post by ratfink »
Tons of parts still available::::::: All 4 doors including: exterior cladding, mirrors, windows, interior panels with switches and bezels. Window motors all work. Interior panels in excellent shape. $400 for all.---- 5 Speed manual transmission with everything needed to change over from an automatic including: flywheel, driveshaft, shifter,bezel, and boot, pedal assy, and crossmember. $500 for all.---- Plastic interior trim pieces. $5 each.---- Front fender cladding and rear quarter cladding. $50 each.---- Tail lights (body). $50 each.---- Tailgate (bare). $100. ----Fuel door and cover. $40. ----Window seals and trim for seals $20 per side. ---- Bumper covers. $100 each. ----And lots more. let me know what you need
greymud
Post by greymud »
Not that my word carries any weight, but happy customer here.
05 NA 5MT
