I have an extra passenger seat frame, from which I have removed the seat cover to replace the cracked upholstery on the driver's seat...you all know what I mean. Now I would like to swap the cover from the seat back, which would fix the sagging net problem, as well as the small rip towards the hinge, but I can't figure out how it was originally installed. Is it just pulled down hard like a tight T-shirt, or is there some secret method, like push-down-and-turn, which nobody would ever guess without a clue. Has anyone been through this?
Looking particularly for information about removing the seat cover from the driver's seat BACK. The seat part was relatively straightforward, so I replaced the seat cover with a perfect example from a junkyard (R) seat. Can't seem to see how to remove the upper part.
How to remove a seatback cover?
