I purchased an 06 Baja that needed some TLC and purchased these parts to get it back on the road.
I had the opportunity to STI swap the Baja and I no longer needed these parts.
Many of these parts are brand new, in the box, and have never been used, others came off of my Baja but still have lots of life in them.
I need the garage space back but can't find it in me to just throw these parts out. Hoping they can find a new home and get someone else back on the road.
All parts are located between Richmond VA and Newport News VA. If you are interested in local pickup PM me and we can sort it out.
I will ship parts at the buyers expense, send me a prepaid FedEx or UPS label and I will slap it on the box and get it in the mail to you.
Please PM me before purchasing a label so I can give you the weight and dimensions of the package.
If interested I can provide images via PM.
Used Parts:
No longer available -- Automatic Transmission and Rear Differential-- Pickup only, ~67k miles, Code: TZ1A4ZCFBC-M6
No longer available -- Front Subframe -- Pickup only, surface rust present, structurally sound as far as I can tell
No longer available -- Rack and Pinion -- Pickup only, works and no known leaks
1 DIN OEM Head Unit
Automatic Shifter Assembly
Automatic Shifter Trim, 92121AE22A
Center Instrument Cluster Trim, 66060AE55A
Rims and Spare Tire -- Pickup only, set of 5, tires will need replaced but rims are in good condition
New Parts:
No longer available -- Control Arm, Right Upper Rear, 20250AG14A
No longer available -- Control Arm, Left Upper Rear, 20250AG15A
No longer available -- Control Arm, Lower Rear, 20250AE01A (two available)
No longer available -- Rear CV Axle, Cardone 66-7370 (two available)
No longer available -- Rear Brake Pads, BC770
No longer available -- ABS Tone Ring, Dorman 917-536 (two available)
No longer available -- Front Left Caliper, ACDelco 18FR2381N
No longer available -- Front Right Caliper, ACDelco 18FR2380N
No longer available -- Rear Left Caliper, ACDelco 18FR1826N
No longer available -- Rear Right Caliper, ACDelco 18FR1825N
No longer available -- Front Rotors, Power Stop JBR957XPR
No longer available -- Rear Rotors, Power Stop JBR945XPR
Cheers! -Zach
Free Parts - Eastern VA
STIswappedBaja
Last edited by STIswappedBaja on Sun Feb 05, 2023 6:31 am, edited 2 times in total.
winnerone23
Re: Free Parts - Eastern VA
Hi, Zach!
Was your Baja a turbo automatic or NA automatic?
If turbo, I'd be in for the trans, rear diff, shifter assembly, and TCU.
Thanks
Troy
Thanks
Troy
STIswappedBaja
Troy,
The Baja was an AT. Let me know if you're interested in the shifter assy. TCU not available as it was still needed when swapping to a 6sp MT.
Best regards,
Zach
Best regards,
Zach
Pm sent interested in trans and diff if Na and tires
Sent from my SM-S908U1 using Tapatalk
Hi Zack, I am interested in all of the new suspension and brake parts if nobody else speaks up for them. I am in Virginia Beach and can pick up
Randy
Randy
