Yesterday I went and saw a 2003. From the street it looked pretty slick, But the bright silver lower trim and support bars can just make some bling in the MI winter.
As we walk up we start to see all the flaws.
Pros :
*Interior was pretty clean, No random french fries and what not.
*Sunroof and all the usual things worked fine.
*ZERO RUST ANYWHERE! Not at the bottoms of the doors,behind the tail gate...None! Car was from Texas.
* Almost every fluid in the car is a picture perfect example of what it should look like. Both DOT3 reservoirs were pure gold,Lime green coolant,cherry red P/S fluid and the entire engine bay was very clean. Could still see paint marks on strut tower bolts under hood. All 3 on each side had a yellow dot on the threads and on the tower mount that lined up
* Timing tensionor,belt,W/P and such all done in the last 24 months. And let me say I truly believed this guy, I also believe he's as naive as a baby deer. You'll see.
Cons:
*Lots of ripped door pulls.
*Texas sun has baked the paint and now the black is turning purple/ashey white at every vertical to horizontal edge, Like the windshield to roof line... Blasted..
* Shifter did go into gear but even then it could be wobbled like in was still in neutral, Never popped out of gear.
*Missing the roof rack crossmembers
* Despite a newer battery and spotless terminals and grounds the HVAC blower motor would speed up or slow down with head lights on and turn signal on. I used my stethoscope and heard bearing noise at the rear of the alternator @ slip rings/end of Stator.
* The steering wheel was right about 5-10* driving straight.
Now for the "HOW THE HEL..... WHY?!"
I checked the oil before we started it, Zero....None.... ....Smoke.....
I talk to what MUST be the most novice of all human beings that I truly believe just has no understanding of anything automotive... They never smelled or checked or anything...
Crossmember under engine, Two pools of oil,each side. Can't see where it's coming from as it goes up and under behind the heads.
The car was 2 qts low. The first room temperature bottle never even showed on the dipstick, The second brought it up to half way. The oil was warm right from the store and into a warm van on it's trip back not 5 minutes ago.
The roof also has two gashes on the top where something deformed the steel,removed all paint and primer. Looks like two rusty brown cat scratched about 3/16th wide in a capitol G type of curl.
So he and I talk for a bit and I try with all my patience to explain to him this and that about engines and why this here is very good and why this is very very bad, he brings up KBB and I sighed but again worked with this guy who I really believe is just so lost and innocent.... anyways, They in Ad wanted $6997 LMAO! Car has 183K on it... Then we go down to 5,500 then 5, finally after what is a truly presidential speech of all speeches I get him to understand why 3,500 is fair and I don't even like that.
What an emotional roller coaster of a day. To have seen,touched and driven a Baja I really get it man, I dig it a lot. I'm so hooked it kinda obsessive LOL, Then to see they're letting it bleed to death right before them.
Would I do an engine swap : Yes
Would I do an engine swap on a car with this fair level of an interior and this poor level of paint.....Not for the purchase price we've discussed.
The valvetrain sounds like a silverware drawer closing, I'd give him a thousand out of my 5 and use the rest for a transplant done at the shop only because It's like 20* out and I'm not doing it in February.
Thanks for reading.
Oh, BTW, Who Admins the F/B page ? I'm waiting for approval ?!
