2003 Black baja - been in accident
timinnc
Post by timinnc »
2003 Subaru Baja - Black
175,000 miles
Automatic
Has been hit and has damage to the drivers rear passenger door, rear quarter panel, wheel and axle.
It has a replaced head gasket, timing belt, water pump, tensioners, cam/crank seals, oil and filter, thermostat/gasket, reseal oil pan, heads resurfaced, new valve stems and seals, both from CV axles, both front ball joints, front brakes - pads and rotors, transmission fluid and filter, power steering pump reservoir O-ring, sway bar linkage, wiper arm bushings, front and rear differential oil changed. All service done at 167,000 (12-10-16) miles cost 4,750
Has -
primitive racing front skid plate - $300 installed at 170,700 miles
Winter tires and wheels - Michelin X-ice XI3 with 4 steel wheels (one is damaged in accident) put on at 170,700 miles - $800
Cover king seat covers - genuine neoprene - $300 put on at 170,000 miles
Weather Tech - floor mats $115
Bed extender
summer tires and original rims
Hard tonneau cover - not color match and not installed
Car interior is super clean.
Would like to sell this car whole. It will start, shift and move just fine. It will need to be moved on a flat bed for any distance due to the damaged rear axle. I have receipts for all work/parts that are listed with a price.
Located in Murphy NC
Re: 2003 Black baja - been in accident
You should post a price for the whole car if you want to sell it that way.
johnpuncheon
Post by johnpuncheon »
I'll buy the bed cover!
mikeeitup
Post by mikeeitup »
A single poster then ups and disappears..... c'mon why bother
thekubas@charter.net
Post by thekubas@charter.net »
am looking for a tonneau cover for 2005 subaru baja thanks
