looking for heated seat relay location
Waynewild
Post by Waynewild »
I have a 05 baja turbo with oem heated seat I’ve replaced switches and still nothing and have no power at switch but I do have power at the fuse please help me find the relay
06Suparu
Re: looking for heated seat relay location
Post by 06Suparu »
Its under the steering column. You have to pull the panel off. I dont remember which one it is though. I just found the wiring diagram i printed out. I believe the relay is actually on the back side of the relay block. Check the fuse for the lighter plug also. When i took the heated seats out of an Outback they shared the same power wire as the lighter plug.
