The brakes in 2006 Baja turbo with 46K miles are starting to feel very soft. The brake pedal is super soft until about the last 1/3 of pedal travel. It is almost to the floor when the brakes starts to grab. The rotors and pads are in great condition.
Initial thoughts were water in the brake lines or the master cylinder going bad.
Would like to know if anyone else has had this problem and is this common on turbo bajas.
Thanks
Rick
2006 Subaru Baja Turbo - Poor Brakes
Re: 2006 Subaru Baja Turbo - Poor Brakes
not common. bleed brakes and check the master cylinder.
