2" Spacers
Re: 2" Spacers
Square tubing part is probably for where the rear suspension links attach to the body (at front of fender well).
FWIW when you do the 2" lift to the front, you will end up with a LOT of down angle on your CV shafts. This could lead to premature wear on CV joints (haven't had issues with mine yet). For this reason, it might be advantageous to install the spacers that drop the engine cradle, rear suspension cradle, driveshaft carrier, and transmission crossmember. Definitely will be needed if lifting more than 2" Dennis
Re: 2" Spacers
Ok so i just.bit the bullet and ordered mine lol. I will get new struts and springs also. Might as well do it all at once and be done with it.
Re: 2" Spacers
Wish I had a better photo but, in person, to me it looks much better.
- KIMG0226.jpeg (626.13 KiB) Viewed 30247 times
Re: 2" Spacers
BTW. You weren't wrong. I will note, unless something got put on wrong, that the front end still is lower than the front end. I wonder of 2 1/2" for the front and 2" for the back would lead to a more linear look. Right now mine has a rake from back (high) to front (lower).
I think it looks good but you can see the difference.
ZUBAJA wrote: ↑Mon Oct 12, 2020 2:30 pm Square tubing part is probably for where the rear suspension links attach to the body (at front of fender well).
Re: 2" Spacers
Sorry for the multiple posts. I just wanted to note that the rear wheels are a little more forward in the rear wheel well. Not sure if that is normal or not but that is what I got.
Re: 2" Spacers
How long did it take to get the lift delivered? I ordered last week..paid for 2 day shipping..they still havent even shipped yet.
Re: 2" Spacers
I didn't do anything expedited. From order to delivery is was just about 3 weeks. I think it was about 1 1/2 for him to make them, a few days before they shipped, and about a week out for delivery.
I will PM you the email address I have for him. He responded to me in a day or so.
Re: 2" Spacers
I think that is SOP. My stock '05 has about 1" of clearance to the front of the rear wheel well and about 1.75" or clearance to the rear...
Re: 2" Spacers
Re: 2" Spacers
Well i got my lift finally. Only took 2 weeks. Glad i paid for 2 day shipping. I see why it was cheaper than ADF. It isnt really a complete kit. It doesnt have the spacers to lower the trailing arms to keep the wheels centered in the openings. Looks like im going to be doing some fabricating anyway. Next time its an ADF lift.
Re: 2" Spacers
Sorry you weren't happy with yours. The kit I bought did have the shims as seen here:
https://www.sjrlift.com/collections/200 ... ailing-arm
I'm fairly new to this so maybe I am not understanding something.
06Suparu wrote: ↑Fri Oct 30, 2020 10:36 am Well i got my lift finally. Only took 2 weeks. Glad i paid for 2 day shipping. I see why it was cheaper than ADF. It isnt really a complete kit. It doesnt have the spacers to lower the trailing arms to keep the wheels centered in the openings. Looks like im going to be doing some fabricating anyway. Next time its an ADF lift.
Re: 2" Spacers
Sorry..that was my bad. The trailing arm spacers are there but it should still have spacers for the subframe.
Re: 2" Spacers
I looked these up and I do see the subframe stuff from ADF. I'm not well versed on this but I didn't think it was critical to have these when going 2"s.
My handling has been fine but of course I don't know, long term, what the new forces may be applying to everything on the underside and what those impacts may be.
Re: 2" Spacers
My understanding is the subframe spacers keep the driveshaft in the proper alignment so it doesnt add stress to the universal joints and the cv joints.
Re: 2" Spacers
There are (or should be) spacers to lower the engine cradle, front control arms, transmission crossmember, drive shaft carrier, rear cradle, and trailing arms. may, or may not have to extend radiator hoses, and may have to modify exhaust hangers. Oh, steering universal coupler. Think I covered everything.
If one simply adds strut spacers, and maybe the trailing arm spacers, you end up with extreme angles on the CV shafts (although mine has been running with the fronts at an angle for about a year now). Dennis
