Replacing cracked boot of the rear bar
Rok71
Post by Rok71 »
Hi,
I have a cracked plastic boot at the bottom of the RHS bar in the trunk. See the picture.
I ordered a replacement part from Subaru.
How do I go about replacing the plastic boot? Do I need to first remove the side panel of the trunk? What else? What is the sequence of the steps?
2006 Baja Sport, 73K
Rok71
Re: Replacing cracked boot of the rear bar
Post by Rok71 »
Perfect! Thank you, greymud!
Rok71
Post by Rok71 »
Did this job today (replaced cracked boot/cover of the trunk bar).
It wasn’t bad. However, after removing the side panel and the trim, one also needs to remove the trim on the side of the cabin leading to the top of the bar. Because the covers must slide on top of the bar through the top, not the bottom.
One piece of advice to those who will be attempting this job. Get enough of side panel and trim clips ahead of the job: you will likely break a few when taking them of
06Suparu
Post by 06Suparu »
It cracks me up that this post showed up. I was going to question how to take it off since i shot mine the other day LOL
Rok71 wrote: Sun Aug 09, 2020 5:50 pm One piece of advice to those who will be attempting this job. Get enough of side panel and trim clips ahead of the job: you will likely break a few when taking them of
That's assuming my Baja has ANY of the little retainers left - they just up and popped off here and there.
Now I am curious. How hard was it to order / get this "boot" / trim piece? Mine on my left side has split (Florida sun). Was it expensive? Dennis
Rok71
Post by Rok71 »
I searched online and found a dealer who sold it for $28 bucks or so. I ordered clips and retainers from the same place for $.97 per piece.
I can find a link if you want
Yes. That would be great. Dennis
greymud
Post by greymud »
Instead of ordering the plastic caps, you may want to consider this DIY:
viewtopic.php?f=2&t=3367
05 NA 5MT
Wow. I never saw that post (and I thought I had been through them all). That is a nice option. I had been (and still may) go for an option of using button fasteners snaps, (or whatever they are called) that would double to hold a tonneau cover on. The only part of that I hadn't figured out yet was fastening the center mounting screw into the slots where the original retainers went. Dennis
Sonnyboy2
Post by Sonnyboy2 »
Where can I buy this part I can’t find it anywhere!!
Leon in PA
Post by Leon in PA »
Sonnyboy2 wrote: Mon Oct 31, 2022 12:20 pm Where can I buy this part I can’t find it anywhere!!
There is a guy on facebook that was working on getting them scanned so they could be 3d printed, there has been no update for a while. I just sent a spare I had to a guy in Alabama, he is looking to 3d print them.
Sonnyboy2
Post by Sonnyboy2 »
Thanks very much for your reply ! Now I have a little hope !
Sonnyboy2
Post by Sonnyboy2 »
Rok71 wrote: Mon Aug 10, 2020 4:41 pm I searched online and found a dealer who sold it for $28 bucks or so. I ordered clips and retainers from the same place for $.97 per piece.
Can you send me that link please?
