Complete Strut Assembly Replacement?
Trucklet
Post by Trucklet »
So the 2003 Baja is getting broken in pretty well now at 235K and although the ride doesn't feel bad, I think I've more than gotten my money's worth out of the original struts. I'd like to replace them myself, but would like to get them as the complete assembly (strut, spring, mount) to make it easy on myself, since these don't require the use of a spring compressor. Monroe sells them as Quick Struts (but not for the Baja). Are there any such kits available for the Baja? I've searched, but before I give up and buy the individual components, thought I would ask if anyone here has found such a package for the 03 Baja (front and rear). Anyone...Bueller?
w.rohr
Re: Complete Strut Assembly Replacement?
Post by w.rohr »
So you mean struts and springs? I think you can use the same springs unless they are damaged. We havent put my new ones in yet but I bought struts and springs off amazon as well as boots (I think they were called). I got the ones for 04-06 baja since they have and extra inch of lift and were also cheaper. If you want I can post part numbers and amazon links if any of that would be helpful.
It sounds like the OP wants quick-struts for ease of installation rather than worry about spring sag. That being said, I'd trust the OE Subaru springs more than aftermarket Indonesian copies. As far as the availability, those are strictly by sales frequency. Taurus, Impala, or other plebeian ride you can get them anywhere. Something with (relatively) low production numbers that caters to a more eclectic crowd and has a very low failure rate: no such luck.
MrCrowley
Post by MrCrowley »
https://bcracingcoilovers.com/products/ ... rs-dr-type
Sent from my XT1585 using Tapatalk
MrCrowley wrote: Fri Apr 07, 2017 1:20 am https://bcracingcoilovers.com/products/ ... rs-dr-type
one track mind much? coilovers aren't in the same category as replacement stock parts and certainly aren't the answer for everything.
