INTERIOR / EXTERIOR TUTORIALS
~~Interior~~
Dismantling the Interior of the Baja - http://tinyurl.com/dismantlinginterior How to take stuff apart!
Dash Light Color Change: http://tinyurl.com/dashlights by YBajaSteve
Useful post concerning bulbs: - http://tinyurl.com/dashlights2
Coin Holder mod into switch/AUX bay: - http://tinyurl.com/coinholderbay
Excellent Subwoofer box tuck: - http://tinyurl.com/bajasub via moonzie at NASIOC
Adding Dash Cup Holder: http://s218.photobucket.com/user/tibugg ... 0.jpg.html These are only found in 00-02 legacies/outbacks from what I understand. Follow guide above for dash light conversion to remove radio trim piece and re-install new one with spring release cup holder.
Window Noise Fix: viewtopic.php?f=3&t=1348&p=15657&hilit= ... ise#p15657
Sean's Remote Start Install: @4:40 https://www.youtube.com/watch?v=4vGgscA6m3o
Momo Steering wheel swap: viewtopic.php?f=2&t=3227
Auto up & down windows: viewtopic.php?f=2&t=3370
Vinyl Wrapping / Painting Interior Thread:  viewtopic.php?f=2&t=3389
~~Exterior~~
Disabling the DRLs: - http://tinyurl.com/disabledrl via scoobymods & Jon S. AKA omahasubaru
useful post concerning this - http://tinyurl.com/disabledrl2
Sport lights custom install: - http://tinyurl.com/sportlights Via YBajaSteve
OEM Sport Light instructions (PDF): - http://tinyurl.com/sportlights2 via Scoobytruck.com
Useful post concerning installation of OEM Sport lights: - http://tinyurl.com/sportlights3
Painting inside headlight trim: - http://tinyurl.com/Headlighttrim
DIY tonneau cover for bed: - http://tinyurl.com/DIYtonneaucover by Sabber from Scoobytruck.com
Painting Grille: - http://tinyurl.com/Grillepaint awesome via YBajaSteve from Scoobytruck.com
Painting Grille 2: - http://tinyurl.com/Grillepaint2
Metal Mesh Behind Grille: - http://tinyurl.com/grillemesh
Custom Grill thread: - viewtopic.php?f=3&t=1472
Two Dirtbike Hauler: viewtopic.php?t=778
JDM "D-type" "kouki" "B4" headlights: http://forums.nasioc.com/forums/showthr ... ?t=2337712
Heated Mirrors: http://forums.nasioc.com/forums/showthr ... ?t=1739090
Replacing Plastic Bed Clips: viewtopic.php?f=2&t=3345&p=18723#p18723
LED bed lights: https://www.amazon.com/SYLVANIA-ZEVO-Wh ... B01CKQP830
When link expires this is the title: "SYLVANIA ZEVO 921 T-16 W16W White LED Bulb, (Contains 2 Bulbs)" Get a 3rd bulb if you want to replace the brake light as well. Link to original post in baja facebook group: https://www.facebook.com/photo.php?fbid ... 578&type=3
Soft Top Canopy: viewtopic.php?f=2&t=3363&p=18950#p18950
Legacy GT Steering Wheel Swap: viewtopic.php?f=2&t=3227&p=19560#p19560
							Modification Tutorials & Links
My Baja Mods
My Baja Mods
- starr-
More Links and Basic Modifications
Post or send me links and I'll add them to the correct category using magical mod powers  ![666 [smilie=666.gif]](./images/smilies/666.gif)
PERFORMANCE / MAINTENANCE TUTORIALS
~~ Performance ~~
STI / WRX Intercooler swap: http://www.mainelysubarus.com/forums/to ... on-04-fxt/
Parts needed: STI tmic, STI Y pipe, STI or WRX Blow off valve, 48-48mm opening silicone elbow hose with 4" arms (if using td04), 2 bolts holding BOV to tmic (Baja-T tmic has studs you can't reuse), STI recirc hose (99071AC540 or 541). ** recommend WRX/STI mounting brackets, T-clamps for recirc and elbow hose, hack the stock baja splitter for better air to new intercooler, and grimspeed intercooler gaskets **
Up pipe: Pretty much all of them will work (direct bolt on). Just shop for 02-07 wrx/sti. Remember your PB blaster and at least a couple of socket extensions. *Be sure to buy new gaskets*
Down pipe: Same as above, most bolt up fine. May need to extend or warp bracket for trans mounting point or grind down remove firewall brace for good clearance. I personally had no issues with clearance on my cheapo ebay bell mouth down pipe for 02-07 wrx/sti.
Shifter bushings: "In "theory" all of the 5-sp subaru kits work. In reality, the front 2-piece is easy and the rear is a monster because it requires some serious force on the shifting rod that runs front-to-back to get the bolts in the rear shifter stay to line up at the appropriate angle. I used a crescent wrench to push up on the socket as I tried to get it started and eventually got it right. I'm never removing it again. Ever." ~DiscoGsus. Baja Performance Part Install Fun Facts and Fitment. Nasioc Baja Forum.
Front / Rear Sway Bars: Whiteline BSF15 (Front swaybar) and BSR12XZ (Rear swaybar).
Endlinks: Kartboy Front endlinks (Sedan bushings), Whiteline KCL144 Rear endlinks (adjustable)
Changing 5th Gear ratio for sti 6th: http://forums.nasioc.com/forums/showthr ... ?t=2293956
2" Lift: https://www.youtube.com/watch?v=YSJHDtZZlJQ
Strut Lift Spacer Template: viewtopic.php?f=3&t=3588&p=19951#p19951
~~ Maintenance ~~
Clutch/Flywheel replacement: http://www.rs25.com/forums/f105/t128163 ... orial.html (Says it's for the 1999 2.5RS, but the procedure is identical for my 2003 Baja)
Engine Removal: http://www.subaruoutback.org/forums/99- ... hread.html
Banjo Bolt Filter Replacement / Removal: https://www.facebook.com/groups/2257951 ... 528926578/
(Link goes to baja owners facebook group. Search "A little reminder for maintenance, replace your banjo filters." by Scott Abele)
~~ Performance ~~
~~ Maintenance ~~
							I like it here....  ![cheeky-grin [smilie=cheeky-grin.gif]](./images/smilies/cheeky-grin.gif)
Re: Mod Tutorial Links
Engine Removal:
Engine Removal:
Re: Modification Tutorials & Links
I was looking for something around Spark plug replacement in  a Turbo Baja. i did find this on Youtibe but not sure how close it matches or if there is better. https://www.youtube.com/watch?v=IAADvX1NLZo Also in the Hella light add on video and istrructions I see that the prewired stuff for activity lights was not used. Anyone ever done that and have any hints?
cspaugh
Mine is NA. That video is the same thing I did for plug replacement, less complicated on the cold air intake, though. I don't have coil packs on the plugs, so just twist to loosen then pull off. Before I pulled the plugs, I used compressed air to clear out the dust that was in the hole to keep anything out of the cylinders. May not be needed, but I haven't had it long. I always use anti seize lube on plugs.
I also replaced the plug wires while I was there.
I haven't added lights yet.
05 NA 5MT
