Need pics of inside bed of Baja (2003) with plastic liner removed
canuck37
Post by canuck37 »
Does anyone have any pics of the inside bed of the Baja (2003 hopefully) with the plastic cladding liner removed?? Particularly interested in the area around where the "roll" bars attach.
Bajahorse24
Re: Need pics of inside bed of Baja (2003) with plastic liner removed
Post by Bajahorse24 »
Depending on what you need it for I can see about removing mine
Sent from my LG-H900 using Tapatalk
Someone sort of already has pics:
viewtopic.php?f=2&t=3262
Model featured is a 2003 Classic, last pictures of the 2nd post show the stripped bed.
P.S they're "sports bars" :P
canuck37
Post by canuck37 »
Thanks! I can't quite get enough resolution to be absolutely sure, but I think they'll help.
I've got some pics that might show different detail. I can find them if you want them. Just curious, what's the motivation?
canuck37
Post by canuck37 »
Was in the process of installing an OEM hard cover on an '03 and didn't have any instructions on where to drill etc. for mounting frame parts. Problem solved eventually.....
danaritter70
Re: RE: How to remove camshaft rear plugs? On Baja03
Post by danaritter70 »
danaritter70 wrote:Help
Sent from my SM-G360T1 using Tapatalk
danaritter70
Thank you. Very much
