2005 Subaru Baja Turbo
181,900 miles
Located in Rochester, NY
(Willing to ship at buyer’s expense)
ADF 2” lift
Kaizen projector headlights
Legacy JDM grill
Bed extender
Legacy wood-grain dash trim and steering wheel (original gray trim will be included)
Tow hitch and wiring
Rear diff skid plate
Engine block heater
Functional boost gauge
Mud flaps
4 brand new tires less than 1000miles
New in the past 2yrs:
Front CV axles, upgraded to HD shafts.
Front brakes - rotors, calipers, lines
Rear rotors and hard lines
Drive shaft and u joints
Valve cover gaskets, oil pan gasket.
Front subframe
Previous owner had timing belt and water pump replaced at 100k, also replaced the turbo and did the screen-filter delete
The Bad:
AC compressor dead
Windshield cracked (hence inspection overdue)
Muffler l missing (but sounds awesome)
Various paint scuffs/scratches, normal for age. Plus one long scratch along the passenger side
Will need new struts soon
Typical undercarriage rust (damn salt!)
I also expect the clutch will be due 20k miles or so.
FS: 2005 Baja Turbo 5sp NY
Re: FS: 2005 Baja Turbo 5sp NY
Still available
Asking $8900
Asking $8900
