wheel bearing noise at 60-65 howling sound
I think I have a bad wheel bearing. Just need to determine which one. It howls around 60-65mph. I jacked it up and all wheels are tight with no play in them so the "jiggle/wiggle" test doesn't help. I'll jack up again and take the wheel off of each hub and then rotate and see if I can hear or feel any non smoothness or resistance when rotating the hubs. Not sure how to pin it down unless the sound becomes more intense and more localized?
Re: wheel bearing noise at 60-65 howling sound
Have you checked the CV axel? I was getting an odd noise and turned out my boot was ripped, also contributing the same side was a faulty caliper
Sent from my LG-H900 using Tapatalk
