Any rust problems with your Baja??
jsingh0072007
Post by jsingh0072007 »
I just noticed this winter that i have rust starting on the driver side rear door jam on the bottom by the plastic step cover if that makes any sense also there is rust starting on the same side right behind the driver side back door were it says AWD on the sides I'll post pics of the rust but has anyone had any rust issues with your Baja????? And if you have corrected the rust how did you do it. i wash my car at once or twice a week in the winterhttp://scoobytruck.com/bb/posting.php?mode=post&f=3#. Thanks!
slagman
Re: Any rust problems with your Baja??
Post by slagman »
Well, it was extremely difficult to remove the caliper bolts when I changed my rotors and pads today. The bolts were rusted so bad that i practically emptied an entire bottle of liquid wrench and nearly broke my arm. The exhaust bolts and gasket by the cat were also near impossible to remove back when I changed the exhaust system, but that is normal. I have no rust on the body. Mine is an 05.
