My mods with Pics
s2000
Re: My recent mods pics included
Post by s2000 » Tue Dec 29, 2009 10:09 pm
Thacrudd wrote:
YBajaSteve wrote:Trucks looking good man!!! You got me beat on the catback exhaust, I really want to do that next but just havent found the time/money.
Thanks man, I'm glad you like it. The exhaust plus the muffler only cost $120 but the stainless tip set me back $80!
nice exhaust and I really like the price :) . I need to get a new exhaust on my baja, but I'm having trouble finding any for the baja. any suggestions on where to find some. And what kind is the one you got?
Thacrudd
Post by Thacrudd » Mon Jun 07, 2010 1:28 pm
I couldn't tell you the brand of muffler actually. They told me but I don't remember :lol:
Updated first post with new mods -
Coin holder mod
new A/T tires [smilie=666.gif]
not pictured: Sound deadening mats
Thacrudd
Post by Thacrudd » Wed Aug 18, 2010 9:10 am
Making that coin holder into a switchbay
follow the "dismantling the interior" thread to access the center console. Push the tabs on the bottom of the coin tray to remove it.
I used a razor and dremel to make vertical cuts in the center fins of the coin holder then used a set of needle nosed pliers to grab and twist the plastic out. Use some sand paper and a razor to remove any excess plastic the lightly run a lighter over it to polish the rough plastic you just created. Using your Dremel, cut out the appropriate holes to make your switches and/or Aux audio cables fit. Install and all done!
Thacrudd
Post by Thacrudd » Wed Aug 18, 2010 10:41 am
Painting your grille
Open your hood and remove the 6 8mm grille bolts and 1 10mm bolt in the very front center. The 3 8mm bolts circled in red are on each side of the grille.
Once you have it off, clean it up real good, scuff the parts to be painted with sand paper and tape off the areas you do not want painted. I chose to paint the chrome trim and not the dark gray areas. Give it ample time to dry and reinstall. A cheap and easy mod to give it some character!
Thacrudd
Post by Thacrudd » Wed Aug 18, 2010 10:47 am
Installing Mesh Behind your Grille
Follow the above post on how to remove your grille - http://tinyurl.com/Grilleremoval
Once you have it off and you have your mesh (source - http://tinyurl.com/metalmesh) cut it to fit behind the large openings. I had leftover mesh so I had to make 2 separate pieces for one side.
I then used JBweld to attach the mesh to the grille. I scuffed up the plastic and stuck it on. I suppose Epoxy could work as well.
Once it hardens just reinstall it. Pretty snazzy!
Thacrudd
Re: My Mods & Mod Tutorial links - Major Thread Overhaul!
Post by Thacrudd » Wed Aug 18, 2010 11:17 am
Completely overhauled this thread to include links to tutorials concerning the Baja. It was previously called "My Recent Mods Pics Included" If you know of any other tutorials that you feel should be included let me know and I'll update the post.
bajachilloopa
Re: My mods with Pics
Post by bajachilloopa » Tue Aug 13, 2013 12:51 am
How did u paint the inner headlight trim? I wanna do this!!!
{BAJAguy and his Cruckinator}
Iownabaja1997
Post by Iownabaja1997 » Wed Nov 20, 2013 8:35 am
What size of tires are the grabbers? My local tire store told me I couldn't fit those on my baja rims :|
Who is online
Users browsing this forum: No registered users and 0 guests
