AWD system on the Baja
flyboyaviator
Post by flyboyaviator »
Where can I find a diagram or pictures of the AWD system on the Baja, I did some search but did not find any thing, thank you for any help..
Re: AWD system on the Baja
Automatic or stick? They are different. Year to year may also be different. Sticks have a (as I recall) fluid (viscous) coupling between front and rear. Automatics (my 06 Forester) have a solenoid actuated clutch pack that functions like a transmission clutch pack or motorcycle clutch. IIRC, this is controlled by the PCM and sensors that tell if one wheel is spinning differently. On this system, there is a fuse you can pull to disable the AWD feature giving you FWD only if there is an issue with your AWD (my Forester had the issue). I pulled the driveshaft, rear tranny case, clutch pack, and cleaned all the plates and the solenoid. A fresh fluid change with Valvoline ATF and my binding issues were gone. The Baja systems should be similar Dennis
EDIT: this article seems to cover it http://www.awdwiki.com/en/subaru/
What info or pics are you looking for?
flyboyaviator
Sorry, for the automatic on 2006 Baja sport. Pictures or diagram. thanks.
The link in the second post has diagrams, including the automatic. Are you looking for a particular picture or diagram?
What are you trying to do?
flyboyaviator wrote: Tue Nov 20, 2018 6:31 pm Sorry, for the automatic on 2006 Baja sport. Pictures or diagram. thanks.
I mean what are you trying to learn from it? is it malfunctioning and you want to troubleshoot/fix it? do you want to swap it out for something else? just want to know how it works for the sake of knowing?
walfredo
Post by walfredo »
