Filled up coolant but it dropped back down in about a month
reddeffect
Post by reddeffect » Tue Dec 20, 2016 7:56 am
Am I looked at needing to replace the head gasket soon? How soon should I do it? 03 baja 110k miles
Re: Filled up coolant but it dropped back down in about a month
Post by kamesama980 » Tue Dec 20, 2016 10:26 am
Failed HG is certainly possible but there are other, easier, possibilities to rule out first (since the EJ HG usually leaks oil long before losing coolant): leaking radiator (which can be nefarious since as it dribbles down the core it gets blown away), heater core, various hoses
Post by anarchy1024 » Tue Dec 20, 2016 11:58 am
Look around the engine bay, and if you see some white crusty residue, it could be evidence of a coolant leak. There are also coolant lines that go into the throttle body, for example, so don't only check around the radiator.
jdlmodelt
Post by jdlmodelt » Fri Jan 06, 2017 7:27 pm
leaking water pump, leaking coolant hoses, leaking heater hoses, leaking gasket on thermostat (check this, another manufacturer's thermostat housing has an "O" ring that fails and the coolant leaks out very slowly like yours.
jdlmodelt
Post by jdlmodelt » Fri Jan 06, 2017 7:31 pm
