05 Baja turbo for sale. Bad shape.
roywitty312
Post by roywitty312 »
Hi all,
I'm parting out a 2005 Baja turbo it's got about 140k miles on it. Everything appears in pretty good shape but the turbo is bad and the oil has metal in it. I made a custom bed cover and it's got an aftermarket touch screen carplay compatible radio installed. Did an STi swap on the turbo and the tmic. New Cobb recirc valve. New (pretty massive) fuel pump installed as well. Email roywitty312@yahoo.com or message here for more info.
tonys123
Re: 05 Baja turbo for sale. Bad shape.
Post by tonys123 »
I'm interested in ac compressor and this right rear licence plate plastic Image
Sent from my SM-N910V using Tapatalk
patrikman
Post by patrikman »
How much for the hitch?
roywitty312
Sorry guys will report back soon, I'm working on selling the car as is. Feel free to make an offer. It is driveable but definitely puts out a lot of smoke for the first few miles. Not recommended.
roywitty312
Allanon93
Post by Allanon93 »
What trans is it
roywitty312
Auto
roywitty312
Looking to sell for $2400 as is
mikeeitup
Post by mikeeitup »
I'm interested in the top antenna assembly if you're parting out. Thanks!
Mike
SVO1
Post by SVO1 »
Still have it? Interested in fixing it up
BajaTim
Post by BajaTim »
Looks like turbo oil feed banjo (union) bolt issue - tiny iscreen inside bolt gets clogged and starves turbo of oil - solution is to reinstall bolt WITHOUT screen otherwise problem will recurr. And other engine oil parts need to be inspected/replaced! For example oil pan - if filled with engine debris banjo bolt filter will keep reclogging and turbo keep failing. Costly fix if dealer does it. I can't believe there is no class action suit as this issue is well known on Forester, Outback, and WRX boards.
SirMyztiq
Post by SirMyztiq »
Interested in the bed cover!
Mattiator
Post by Mattiator »
I'd like to buy the roof crossbars if they're available.
