Trailer wiring harness
tiogaco
Post by tiogaco »
The trailer wiring harness on my baja is all corroded and busted. This is on the car side, not on the trailer side.
I can see a connector that splits and gives me the end to hook up trailer lights and the other then which goes into the body and I think up into the rear taillight. It looks like I can pop off the rear external plastic trim and the rear taillight to access this.
Does this sound right? Part number for the replacement?
Re: Trailer wiring harness
There is an access plug under the right rear for a "plug and play" trailer light system. It is capped from the factory. You remove the cap, plug in the harness (w/ module), secure the wires, and you are good to go. Dennis
tiogaco
Post by tiogaco »
Yup, that's the part that is messed up.
If you look up under there, you can see where that cable Ys goes up into I think the rear passenger tail lights.
