Identify a connector, please
oldpro
Post by oldpro »
Today I replaced the battery on my '05. When I pulled the old battery up and out I saw an unused socket (2-conductor) on the wiring leading to the windshield washer pump.
Any idea what would plug into that?
Oldpro
Re: Identify a connector, please
I don't remember seeing an unused connector on mine...
Does the connector look like the windshield washer pump connector, but keyed differently? If so, maybe you have a wiring harness from an Outback/Legacy, and that connector could be for the rear window washer pump.
brucey
Post by brucey »
It's unused.
Subaru just used the same harness for the Baja in that area as they did in the Outback.
The same symptom is in Outback Sedans.
It's for a rear sprayer motor but since the Baja doesn't have it they just have it floating around.
oldpro
Post by oldpro »
Thanks, guys; that makes perfect sense. :D
Oldpro
