Daytime Running Lights
Anyone know how to disable daytime running lights?
there was a long and detailed discussion about how to disable them on the NASIOC.COM forums. Search the past posts in the Baja thread and I'm sure you'll find what you're looking for. There were also instructions on how to make the driving lights operate independently of the headlights.
good luck
Jp
good luck
Jp
I don't know if the 05 is the same as an 04,but theres a black box on the right side of the steering column i think maybe left can't remember.Theres 2 connectors that plug into this box,white & black.They plug in the backside facing the firewall.I think you unplug the white connector to disable DRLs and thats all you have to do.Good Luck
I haven't tried the daytime runnin lite thing yet, I did try to rewire the fog lites, but the 03 is wired different. All I got was shorts and a dead battery. It seems the 03 fog lamp relay is under the hood, so when I get bored sometime, I will look into that problem again. There has to be a way to make them work with the high beams. Mike
- cyphergirl
- Flowmastered87GL
- cyphergirl
Baja DRL Disable
I don't necessarily consider myself to be a control freak, but I too am not a fan of DRL's. As for the soccer mom in the Chevy f*** you mobile (Suburban)...if she can't see my yellow Baja, I doubt she'll notice my DRL's. Anywho, check out http://www.lightsout.org/disable.html for the instructions, although I haven't yet disabled my own. hmmm...
j
MY03 Baja Sport
Baja Yellow
MY03 Baja Sport
Baja Yellow
I've tried everything that was suggested and still no go.
The connection on the box on the steering column did turn out the DRL's, but then the low beams did not work.
I think if I could find the DRL dropping resistor or the relay I could disable these stupid things.
