I own a 2006 Baja, after a transmission swap at 288000 miles I'm looking to make it a little more sporty you know? Any ideas as to what Other models I should use to get parts that would be compatible. The Baja isn't exactly the easiest car to find performance parts for in my experience.
Looking to lower my Baja, not sure what springs to use or what other Subaru to search for them for to buy?
Re: RE: Looking to lower my Baja, not sure what springs to use or what other Subaru to search for them for to buy?
https://bcracingcoilovers.com/products/ ... rs-dr-typesyotos885 wrote:I own a 2006 Baja, after a transmission swap at 288000 miles I'm looking to make it a little more sporty you know? Any ideas as to what Other models I should use to get parts that would be compatible. The Baja isn't exactly the easiest car to find performance parts for in my experience.
Sent from my XT1585 using Tapatalk
Re: Looking to lower my Baja, not sure what springs to use or what other Subaru to search for them for to buy?
#1 criteria: What's your budget?
#2: what's your intended use/why are you lowering it?
#3: doing it yourself or paying others?
All of this feeds into #4: how legit do you want it to be (IE cut springs vs mix n match stock parts vs coilovers)
03 baja springs/struts are good for about 1". ouback/legacy ought to be good for another inch ish if I recall. If you have the money and your intended use justifies it, coilovers are a nice pre-packaged deal but can have other issues like road noise transmission and accelerated wear of other already somewhat worn parts like bushings, especially if you don't re-index the bushings.
