Nubie Horn
Nubie Horn
I recently bought a '03 Baja. I knew that it had some issues when I bought it. First, the head gasket leak led to an engine replacement. Then the power steering pump made a lot of a noise. That was an easy fix, tighten the belt. The window washer did not work. The terminals were cleaned and it works. Finally, the horn did not work. I could not find where the original horn nor the wiring. I have up and wired it into the fuse box to the horn relay. I opened the inner fenders and did not see any horn or wires. The bracket in front of the radiator did not have any horn or wire. So, where would it be?
Re: Nubie Horn
The horns should be right in front of the radiator, mounted in the same area as the hood latch, with the electrical connector down near the bottom of the rad...
- wire.JPG (53.13 KiB) Viewed 2952 times
- horns2.JPG (139.83 KiB) Viewed 2952 times
- horns.JPG (128.08 KiB) Viewed 2952 times
Re: Nubie Horn
The horn was not there when I first began to look for it. It is there now and connected to the hotn relay.
