While trying to loosen the bolts on the transmission cross-member to the drop the transmission, the blind nut (nut inside the body of the car) on the front-passenger side broke its welds before the bolt came out, so it was just spinning. Looks like the mechanic who replaced it last cross-threaded it... This appears to be a common problem:
http://forums.nasioc.com/forums/showthr ... ?t=2362408
https://www.google.com/search?q=subaru+ ... r+nut+weld
The problem bolt is #1 in this diagram:
http://parts.subaru.com/a/Subaru_2003_B ... 10-03.html
And it looks like the most common solution is to cut a hole in the floor and peel back the metal to access the nut. Problem is, I couldn't find any pictures of where to cut, so I thought I'd post some pictures to help anyone else who might be in this situation. Not the best cutting job in the world by a long way, but it worked...
Front transmission cross-member blind nut broke welds
- 20160424_130503.jpg (280.94 KiB) Viewed 2076 times
- 20160424_133020.jpg (266.1 KiB) Viewed 2076 times
Re: Front transmission cross-member blind nut broke welds
Also, of those wanting to pull the transmission, this is a really good guide, and is accurate at least for the NAs:
http://www.rs25.com/forums/f105/t128163 ... orial.html (except for the torque spec on the front bolt... should be around 75ft-lbs, not 101ft-lbs).
