300K suspension service
With 290,000+ miles on my 2003 its about time to do some replaceing of worn parts. I bought a used set of low mile strut assemblies off an 2006, and i'm waiting for my set of one inch spacers to come in. I'm am just wondering what else I should replace while I am under there?. I have already replaced brake pads, rotors, calipers, and brake lines. also what size tire should I stuff under there to fill in my new two inch lift?
Re: 300K suspension service
There are a few bushings you can replace with white line polyurethane ones. How tight is the steering? My 2003 is at a measly 200k.... So I am interested.
@ Takaaco did you replace the calipers with aftermarket?
i found a low mileage oem settomato_88 wrote:@ Takaaco did you replace the calipers with aftermarket?
