Hidden roof light plug???
I have been reading some about adding roof lights to the Baja. Some claim they are pre-wired for lights. Where might I find the plug end for the lights? Thanks
Re: Hidden roof light plug???
My Baja has the factory light kit, while it comes with a super nice button to add to the dash, I can tell you that the roof wiring does not look pre-wired in the least, definitely added the wiring down the right rail and under the rear plastic fascia, then into the cab. Once into the cab, then not sure if there was wiring already laid to go from there to the dash where the button is plugged in.mowillie wrote:I have been reading some about adding roof lights to the Baja. Some claim they are pre-wired for lights. Where might I find the plug end for the lights? Thanks
Download the Sport Lamp manual from the Baja library up top.... they have all the info.
It's there. I installed the oem lights after I bought the baja 2 yrs ago. IIRC the plug was on the right side of the car along the rear window. Soober man is also correct. The instructions are easily downloaded and should show the exact location...
