Oil level reading
Oil level reading
Recently purchased 2005 NA Baja with rebuilt engine, new w/p, timing belt etc, etc... When I first checked the oil dipstick it read WAY too much oil. I immediately drained the oil but got the correct amount of oil (about 4.25 qt,) replaced the oil and of course still read WAY too much oil. Could see repairs made to the tube on closer inspection. Wrong tube? Wrong dipstick?
Re: Oil level reading
The dipstick has a notch above the upper level.
Just after driving or while the engine is warm, the engine
oil level reading may be in a range between the
upper level and the notch mark. This is caused by thermal
expansion of the engine oil.
If you'd like, I can measure my tube and dipstick lengths. I have a 2003 NA (I'd think they'd be the same as the 2005 NA, but not 100% sure).
That would be helpful, thanks.
By "overfill" I mean theat the level reads past the first twist, past the second twist and a half inch above that! It seems to read about 3-4 quarts over and yet it's not. I understand there is a 20006 STI oil pan that's different. If that were installed, might that account for the readings? I think I'm gonna stop by the local boneyard and see if I can find the exact same engine and go from there.
Where are you? Having another Baja to swap dipsticks with would be a good test.
05 NA 5MT
I'm in Albuquerque and there are no Bajas in any junk yard but there are plenty of subarus.
It's the same dipstick as the same year legacy
2000 Impreza RS Coupe, RSTI swap in progress
Just to be sure we're on the same page (is the device plugged in and the power switch turned on...) because I don't know you or your car knowledge.
Remember to let the oil settle a few minutes before checking it.
Pull the dipstick
clean it
insert the dipstick
read it
When you have drained and filled the oil, start the engine to fill the oil filter and passages that may have drained then let the car sit a minute or two.
Pull the dipstick
clean it
insert the dipstick
read it
I know, I've been looking. Found a nice one in Missoula Mt. It had 57 K miles, I bid 3200 and someone else bid 3250, but it didn't meet reserve. I don't know how it ended. If I had won, I would have had almost 5000 to get it out of the yard plus 400 I paid the broker to bid, the 1700 shipping. I would have been looking at close to 7000 in a nice little Baja Turbo with the left front end missing.
I just bought this 2006 Baja Turbo, one small lady owner, never wrecked, great maintenance record ( I talked to her mechanic), 110k miles and looks new. Price 9000.00.
- Baja Longview 5.jpg (103.14 KiB) Viewed 502 times
Just to weigh in on this, I, too, am often frustrated by the dipstick in both the Baja and our '10 Forester. Example; change the oil and filter adding the recommended amount of oil, button everything up and the dipstick is right on the full mark. Go for a drive, park the car and then check the oil the next morning and it is a few inches above the full mark. This is consistent and happens on both of these cars, though the same cannot be said for our '16 Outback; it always reads as you would expect.
On our Baja and Forester, it seems that if the oil is checked within a couple hours of a drive, then you can get a good reading. If it sits overnight or longer, I am assuming oil must drain down from other places, since I don't think it is making it. Anymore, pretty much as long as I pull the dipstick out and there is oil on it, I am not concerned. I know I start with the right amount after the change, and just check it at an appropriate time after a shutdown when I need an actual level for monitoring/adding oil, as both do need topped up a few times between changes.
-John
-John
Just changed the oil an hour ago in mine. (Barely, the hood wouldn't release. Had a friend come over and help then worked and lubed the heck out of the latch. Good sign I guess that I haven't had to open it much). I'm in the same mindset: It leaks enough oil as long as there is a reading I'm happy. I'm glad it's not a VW or Mercedes that has a dash light and problems if it's 1/4 qt over-full.kensei wrote: ↑Fri Oct 18, 2019 8:23 amJust to weigh in on this, I, too, am often frustrated by the dipstick in both the Baja and our '10 Forester. Example; change the oil and filter adding the recommended amount of oil, button everything up and the dipstick is right on the full mark. Go for a drive, park the car and then check the oil the next morning and it is a few inches above the full mark. This is consistent and happens on both of these cars, though the same cannot be said for our '16 Outback; it always reads as you would expect.
-John
I almost always change mine using a 5 quart jug of oil. I usually measure out and fill about 4 quarts of oil plus what I can fit in the filter. Then start it, check for leaks, and recheck it (always a little under the full mark). Then I take it for a road test around the neighborhood and recheck and add after it cools from the drive. Dennis
Well, I bought the car. It looks new and drives like new. I knew I had to wear parts to replace. It has not had the timing belt replaced and also the water pump is original. I talked to her mechanic and he told me he replaced the turbo and did all the checkups. Sounded like he knew what he was talking about. The dealer said he had repaired the A/C. When I got there the car started right up and ran so quiet, I couldn't hear it. I signed all the paperwork and we headed for Dallas, headed home. I noticed the car didn't have much power, but I was going along about 65 mph which was fine by me. as we got past Dallas, I decided to turn on the A/C and of course it didn't work. So there were 2 lies that I had been told. I don't believe the Turbo is working, because I think I'm down about 100 HP. That's the way it goes with me on used cars, I always have to spend 3 or 4 thousand to get them sorted.harleyjohn45 wrote: ↑Wed Oct 16, 2019 2:48 pmI know, I've been looking. Found a nice one in Missoula Mt. It had 57 K miles, I bid 3200 and someone else bid 3250, but it didn't meet reserve. I don't know how it ended. If I had won, I would have had almost 5000 to get it out of the yard plus 400 I paid the broker to bid, the 1700 shipping. I would have been looking at close to 7000 in a nice little Baja Turbo with the left front end missing.
One great thing is this car has a pioneer stereo, and I could pick up 15 or 20 FM stations all the way from Long View Texas to Alto, NM. This vehicle has great sound. Oh, one last thing I got a check engine light about 5 miles after I left the dealership. That caused the Cruise control to not work. If the Check engine light is a o2 code, that would be an exhaust gas sensor, and I understand that can rob power.
You can bet I will leave him negative feedback that will burn his ears. I hate people who lie.
Pull that turbo banjo bolt filter ASAP! If the turbo was replaced, I guarantee that filter wasn't pulled- this'll starve your turbo if clogged and cause an eventual catastrophic turbo failure with a high probability of taking the engine with it.
Also check for any leaks in the vacuum tubes, might be the source of your low power issues.
Is it throwing a P0420 code?
