New Baja Owner
New Baja Owner
Hey everyone
I just got a new 05 baja turbo for the wife....Its a great little car wit some power..Just wanted to say Hi and see if there is anything i should be looking out for down the road...Ive been reading some threads here and there but just wanted to see if anyone had any tips for me...Like the oil i do all of my oil changes on my SpecV...But what type of oil should i be putting in there?? i want full Syn but whats a good brand for the BAJA T?? And also (Sorry ) But is there a FSM book on this car on the net???
Thanks
Thanks
I've used Mobil one in mine after the first oil change. Which is most likly the best for ease of finding it. Also I just replaced my Diff/trany fluid with Amsol. The place that did it Suggested the rear be changed every 10,000 because of how little fluid is in there and the amount of heat that is generated. I changed it at 15k and they said it was VERY black coming out. This is something everyone should do quickly.
New Sticky?
There seems to be a good piece of advice there. Should a Sticky (non comment thread) be started for good tips like this so they can all be in place?
- Mr. Jalapeño
Re: New Sticky?
http://scoobytruck.com/bb/viewtopic.php?p=2196#2196Atomic Baja wrote:There seems to be a good piece of advice there. Should a Sticky (non comment thread) be started for good tips like this so they can all be in place?
Let's give it a shot!
hey thanksholland_patrick wrote:I've used Mobil one in mine after the first oil change. Which is most likly the best for ease of finding it. Also I just replaced my Diff/trany fluid with Amsol. The place that did it Suggested the rear be changed every 10,000 because of how little fluid is in there and the amount of heat that is generated. I changed it at 15k and they said it was VERY black coming out. This is something everyone should do quickly.
Moble one was what i first in my car then switched to royal purple...Should i just stick wit the moble1? the rear be changed??? what rear tran fluid are u talking about or is there something i dunno??? yea amsol is what i put in my moms civic and it seems to be doing good...Hows it working wit yrs do u have stick or auto???
Isn't the service interval supposed to be 30K for those fluids ?holland_patrick wrote:I've used Mobil one in mine after the first oil change. Which is most likly the best for ease of finding it. Also I just replaced my Diff/trany fluid with Amsol. The place that did it Suggested the rear be changed every 10,000 because of how little fluid is in there and the amount of heat that is generated. I changed it at 15k and they said it was VERY black coming out. This is something everyone should do quickly.
I guess I'm just skeptical because I am not aware of any new vehicle sold today that would require a diff/tranny fluid changes every 10K. Many new cars are made to be serviced at the 100,000 mile mark.
I changed my auto trans fluid at 20,000 miles, but that is because I had just bought the Baja, and wanted new fluid in it. The rest of the fluids, front and rear diff, came out at 40,000. None of them looked bad, they were a bit black, but still had the old diff fluid stink, so I figure thats ok. I will change them all again at about 60,000, because I am towing my ATV around, and that is a bit of work for the Baja. I usually change all those fluids about every 30,000 miles, I figure that it is cheap insurance to keep breaddowns and probs to a minumum. Mike
Any time you put powewr to the wheels is needs to be Lubed up. SO the front is covered with the frontdiff/transmission all in one unit. The rear has a pumkin back there that is the rear end diff. Yes I know the book says 30k but with the stuff I lug around I figured better to be safe then sorry. I have pretty much changed my diff/trany/transfur case in the jeep every year and that is going well over 200k and 11 years now that is staying power. Ya i did pay someone to do it but why should i deal with disposile..
PS the amsol seems to be working fine
Aight cool thanks...Yea me to im coming from a front wheel drive car to an AWD...So its confusing me as well..Just want to get as much inof as i can so when i do change it ill know whats up....yellowblaze wrote:We use royal purple in the scoob and the 00 stang, seems to work well for both.
How hard was the diff fluid change? I havent looked closely at the diffs yet....Patrick, you said the front is the tranny (& tranny filter?)& diff? Is there a transfer case? This AWD vs 4X4 is a bit confusing....
Yea i do but still get no replysmbaksic wrote:Hey Scoob43, make sure when you post that the box that says "Notify Me When a Reply Is Posted" box is checked, then you will get an e-mail when someone replys. Mike
Another question has anyone retro fitted HID projectors in there baja...Not just get those crappy hid kit...But projectors in there houseing?? Im thinking of doing it to my wifes car as well but its just to much work...Plus the 05 headlight have a different hi/low location..the only problem i might have is the high is right below the low so i dunno if i can fit a projector of anykind single or bi-xenon projector.....
