Project Off Road Baja
Rwilliamtaylor
Post by Rwilliamtaylor »
Project Baja Done.
4 “ lift plus lot’s off fender trimming
Method Race Wheels
BFG Ko2s
Skid plates
Brush Bar
Custom Winch Mount
Off Road Lights
mikeeitup
Re: Project Off Road Baja
Post by mikeeitup »
Nice! Who made the lift kit for you?
Rwilliamtaylor
Anderson Design Fabrication.
Rwilliamtaylor
That is one sexy sport! Excellent job on the mod!
Question: What model bush bar and how does it mount and did the bumper bottom crossmember have to be cut out in order to mount it?
mikeeitup
Post by mikeeitup »
I am a little nervous about purchasing from them. For the 200 more than the competitor, you do get the brace BUT it does not come coated. that worries me. Thoughts?
Airborneguy
Post by Airborneguy »
How did you wire the top light bar? Trying to figure how I want to do mine.
Rwilliamtaylor
Guacamole wrote:That is one sexy sport! Excellent job on the mod!
It’s a Westin bush bar (not intended for a baja). I have a 3/16 in skid plate that the bush bar bolts to. I didn’t have to cut the bumper skin bottom crossmember in fact I just trimmed it at first and then I decided to ad an upper skid plate so I trimmed the bottom bar away. Here’s a pic that shows before the winch and trimming.
Rwilliamtaylor
mikeeitup wrote:I am a little nervous about purchasing from them. For the 200 more than the competitor, you do get the brace BUT it does not come coated. that worries me. Thoughts?
The parts are pretty heavy gauge so I didn’t worry about the coating. I’ve found that plastidip works well as an alternative to powder coating and is easy to apply. I used PD on a crosstrek brush bar and winch mount I built.
I’ve installed 2 ADF lifts now and both were high quality parts.
Last edited by Rwilliamtaylor on Thu Oct 04, 2018 4:35 pm, edited 2 times in total.
Rwilliamtaylor
Airborneguy wrote:How did you wire the top light bar? Trying to figure how I want to do mine.
I used a cable routing channel sealed with silicone. It runs up the edge of the windshield. You have to look closely to see it. If you zoom this photo you’ll see it. I found the wires for the 42” bar were too thick to run under the windshield seal. I also installed a switch in the dash panel. If you look behind it there is room for an aftermarket switch. If that didn’t work I was going to use the cargo lamp switch since I never use the bed light.
Airborneguy
Rwilliamtaylor wrote:
Thu Oct 04, 2018 4:41 pm
Thank you! I’m probably going to do it this way as well.
Airborneguy
Where did you get that channel?
walfredo
Post by walfredo »
Are you running 16" or 15" methods? What offset? What size tires?
I didnt think 15's would fit over the brakes - so I went with Motegi MR139 16's with 215/70/16 Grabber APT's - I dont quite have the offset (or tire width) Id like though and am thinking of going 15s (with more tire choices to boot).
Looking good!
Rwilliamtaylor
Airborneguy wrote:Where did you get that channel?
Ordered it on Amazon.
One-Cord Channel Cable Concealer - CMC-03 Mini Cover Cable Management System - 125" Raceway Kit for Hiding a Single Ethernet Cable, Speaker Wire, Floor Lamp Cord - 8X L15.6in, W0.59in H0.39in, Black https://www.amazon.com/dp/B07D8V7RZ1/re ... YBb772BDXW
Rwilliamtaylor
walfredo wrote:Are you running 16" or 15" methods? What offset? What size tires?
Looking good!
They are 15” Methods with 15 offset. I run 235/75/15 BFG KO2s.
I also have a 1” wheel spacer, but I ran them without the spacer as well with no problems.
