Has anyone figured out how to lower a Baja without purchasing an expensive coil over setup?
What springs? What struts?
Suspension
Re: Suspension
Legacy GT struts and springs would work. I got a set of used JDM Bilstein shocks and struts, which ended up making my Baja too low...scraped the ground when exiting my apartment driveway. Next need to try a combination of my two sets to see what works best.
- 20161114_201517.jpg (280.82 KiB) Viewed 4581 times
- 20161114_221525.jpg (218.9 KiB) Viewed 4581 times
- 20170115_213506.jpg (202.19 KiB) Viewed 4581 times
Re: Suspension
And the front... The photo isn't of the Bilstein front, but the size is the same. Got these https://www.amazon.com/gp/product/B00HS0H8P0/ for my 2002 Outback, which uses parts compatible with the Baja.
The biggest thing I found with getting Gen 3 Legacy shocks/springs and putting them in the Baja or Outback wagon is the rear sits a bit too low, making it look like it's overloaded. To compensate, either you can fit stiffer springs, or a spacer between the chassis and top mount.
- 20160628_195838.jpg (106.93 KiB) Viewed 4579 times
- 20160922_183618.jpg (149.55 KiB) Viewed 4579 times
- 20161114_230131.jpg (161.73 KiB) Viewed 4579 times
Re: Suspension
You still looking for a baja snug top shell. I have a silver one for sale. Can text me at 530 903 1623 bill
