Hello from NV! So I was disabling my DRL's under my dash on my 2004 baja and noticed a black box with a red dial you can move with a Phillips screw driver from min. To max. I want to say it's a brake controler but I have no set up in the back for towing. Also, there's a small plugin thats visible from the sitting position that has a reset button recessed inside of it. Any ideas?
Mystery box
Mystery box
- 14646579036901245940263.jpg (3.95 MiB) Viewed 5979 times
Re: Mystery box
No idea... haven't seen that before. Aftermarket alarm?
Any part or ID numbers on the box?
Re: Mystery box
Is it for that box mounted at the edge? Radar detector? That would explain the min-max.
Re: Mystery box
90% sure its an aftermarket alarm, the red wire is the antenna and the min/max is sensitivity.
Re: Mystery box
Thays exactly what it is! Good job! I took it off to inspect the back the sure enough it's an alarm. Thanks for the help!w.rohr wrote:90% sure its an aftermarket alarm, the red wire is the antenna and the min/max is sensitivity.
