yellowing moulding
mattada
yellowing moulding
Post by mattada »
Anyone else have the trim on their moulding yellowing?
Its just the fenders, but its all 4 sides. Its not something that can be scrubbed off, and scrubbing / scraping doenst make it better or worse.
canuck37
Re: yellowing moulding
Post by canuck37 »
mattada wrote:Anyone else have the trim on their moulding yellowing?
Common problem - wind and debris strip seem to off the paint as air passes over the leading edge.
I haven't found an easy fix.....a good pin-striper could probably fix it fairly cheaply....
mattada
Post by mattada »
yeah, i was thinking about just painting it. with carful taping and masking I bet I could rattle can it.
Ryantids
Post by Ryantids »
I have run into this problem as well. It seems that you may be able to pull out the molding but does anyone know if you can purchase a replacement.
You can get a replacement but they are black
Zombaja
Post by Zombaja »
is there any issues with getting paint to stick to that moulding?
I figured I'd just go over mine with a small jar of paint and a thin hobby brush.
Or spray the whole thing when I do the bedliner fender spray.
Ramathorn178
Post by Ramathorn178 »
hahahaha, silver sharpie worked for me [smilie=666.gif]
Killer B
Post by Killer B »
Ramathorn178 wrote:hahahaha, silver sharpie worked for me [smilie=666.gif]
My moulding is in the beginning stages of yellowing in certain areas and I was thinking about the silver sharpie method the other day. Is a sharpie all you need to do this or do you also need something to put on top of it after it dries?
ags0702
Post by ags0702 »
I am interested in the silver sharpie as well...subscribing to thread.
sfeather11
Post by sfeather11 »
Used the sharpie on mine a few weeks ago. Very easy to do. Get yourself a silver "metallic" sharpie and color it in! Nothing else needed. I did 2 coats a day apart. While it is not a perfect paint job, the molding is much, much less noticeable than before. I stumbled across the sharpies at a craft store (looking for model paint), but I'm sure office supply stores would carry them too. Make sure to get silver metallic, it is a very close match to oem... Peace!
Killer B
Post by Killer B »
Thanks for the info, sfeather11! I will look for a silver metallic sharpie next time I'm out and about and fill in the areas that are starting to yellow.
AintGotNoSol
Post by AintGotNoSol »
Good info! I have this same issue on my Silver 06. I'll try the sharpie as well!
tsmart
Post by tsmart »
I had this problem on mine too, I got a small blade screwdriver and carefully carefully pulled out this molding. Then I went to an auto paint store and got a spray can of prep and then a spray can of silver made just for this purpose. I painted the molding and carefully re installed it with the same screw driver and a little heat from a hair dryer to make it just a bit more flexible. That was 4 years ago and it still looks like new.
When I originally checked out to see if I could buy this molding, Subaru dealer said only way is if I got the entire cladding quarters.
Maybe ROCK AUTO but i doubt it.
