Hey everyone long story short i just drove across the country, found out i troe the inner passenger side cv boot and need to replace it. It sprayed grease all over the cat. Today driving the check engine light came on. Do you think it is the o2 sensor or somthing eles and is it related to cv boot. Does anyone also know a good cheap and reliable mechanic in the denver area?
mike
check engine light?
Re: check engine light?
And most autozone's, advance auto's have a code reader and will read the code for free. If it is the O2 sensor on the side of the bad axle boot, it could be the grease on the sensor causing the problem. Clean it off and it may go away.
http://www.retroroo.com/
Shawn has been working on Soob's for years. I'm not sure if he still has his Baja, but the Mudrat bumper on mine used to be on his.
