Will any Subaru spare tire fit Baja?
Baja_CNY
Post by Baja_CNY »
Hi
I have a 2006 Baja and need a new spare tire and rim.
I was at the dealer yesterday and the parts manager told me any spare tire from a Subaru,
other than the STI, would work because they all use the 5 X 100 pattern.
I'm looking on eBay and if this is true, I wonder why spares are listed for specific models and years?
For example, there are several listings for 90 - 97 Legacy spare tires, which the parts guy said would work.
Is it true that I can use a rim and donut tire from any Subaru other tham STI?
Thanks a lot . . . . Brian
Benhart21
Re: Will any Subaru spare tire fit Baja?
Post by Benhart21 »
Can't say I have extensive knowledge of spare tires, but I wouldn't listen to that guy. Sure, they'll bolt on, but keep in mind that the Baja/Forester(possibly 05+ Outback) have a larger diameter tire than the Impreza and Legacy. Putting on a spare that has a much smaller diameter than the other wheels on the vehicle will wreak havoc on the differentials. I believe that it's something like if there's a 2/32" difference in the tread on your tires, they say to replace them or there is potential for damage. The difference between a 205/55/16(stock '02-'05 WRX size) versus a 225/60/16(stock Baja size) is about 1.7".
Is your spare missing? Why not just buy an appropriately sized spare tire?
Jommie
Post by Jommie »
Get a spare that has the exact same measurements as the 4 wheels you use.
Same size and offset on the rim, and same size tyre. If possible, try get same brand/model of tyre.
Also, if you need to replace 1 wheel, where the thread is 2-3 or more worn down, you should consider replacing all 4 wheels. The differentials does not like having different diameter on the wheels, and replacing/repairing a diff is costly.
That said - Subaru diff's seems to be a bit more sturdy that those found on AWD Volvo/Audi/Bmw's, but still wouldn't recommend trying to find the limit. :wink:
As previous poster said - default on a Baja are 16" wheels with 225/60/16 size tyre. Offset on rim should be 48.
Baja_CNY
Post by Baja_CNY »
Benhart21 and Jommie I really appreciate your help.
Thank you and sorry I didn't say it sooner.
I needed a replacement because mine was missing.
Got a genuine Baja tire and rim from eBay.
Thanks again . . . Brian
